Chuck -- The paper pulleys work just fine with a little belt dressing every now and then, as needed. The surface is generally smooth, although not bright or shiny. If you look real close you can see the lamination. If the belt is running true you won't get any grooves, unless you use, say, a four-inch belt (it's designed for a six-inch belt). Biggest problem with them, though, is that they don't like being left outdoors. Many paper pulleys rotted away over the decades, leaving just the hub, a small tin ring and the rivets that held the paper on. (Good for business for the folks in Columbia, TN, though!) I have an original Rockwood pulley that was taken from a Model F long ago and put into storage until a couple of years ago. (Rockwood was a major producer of belt pulleys for the Fordson F and other tractors of the 1920s, and Paper Pulleys, Inc. is a direct descendant of Rockwood according to the "about us" page on their website.) The pulley is at my folks' place, though, which is a couple of hours away, so I won't be able to take a picture for you for a little while. -- Maine Fordson
