Fordson Tractors Discussion Forum
'58 Fordson Major fuel injector pump
kenb
07-09-2007 17:54:16
I got water in my fuel injector and now I can't keep it running. Is the fuel injector fried? Any suggestions?
bison
07-11-2007 22:52:12
 Re: '58 Fordson Major fuel injector pump in reply to kenb, 07-09-2007 17:54:16
you have to drain the water from the tank and all lines, change fuel filter,s. loosen fuelinjector lines and prime the whole system.
Water destroys a injector in short order
jboettcher
07-10-2007 09:50:31
Bleed it. Just water.
Myassitis from Mo.
kenb
07-12-2007 17:22:00
 Re: '58 Fordson Major fuel injector pump in reply to jboettcher, 07-10-2007 09:50:31
Got water in tank.Drained tank, changed filters,bleed lines at injector pump.Still I can not keep tractor running?Looks like fuel is not coming out of two injector lines strong.Will stay running on starting fluid!
tiresntracks
07-12-2007 22:23:28
 Re: '58 Fordson Major fuel injector pump in reply to kenb, 07-12-2007 17:22:00
I'm sure that you probably already did this, but did you open the bleeder on the injector pump and pump the hand lever on the lift pump until you have clear fuel with no air coming out the bleeder? How long was the water in the injector pump? Was it all water or a little water mixed with the diesel?
