Fordson Tractors Discussion Forum
FMD Compression Release
Greyson
07-12-2007 13:43:10
What is the purpose of the compression release handle on my Fordson Major Diesel. About the only thing i can figure is if the battery is low, you can release the compression and spin the engine up before throwing the handle to compress and hoping it fires. Just wondering.
hammerhead
07-16-2007 09:35:21
 Re: FMD Compression Release in reply to Greyson, 07-12-2007 13:43:10
my understanding is it is too warm up the cylinders before starting in cold weather by using the manual crank handle and should not be used to start the engine.
Jim krem
07-12-2007 21:09:14
Be carefull when using compresion relese for starting herd storys of bent valves and push rods,I have used mine on my major with no probs yet.Talk with Brian Dye on the fordson page and he will say same, any half good major starts so easy its shouldnt be needed. it was stated in ops man. that it was for breaking oil film on cold engine cranking by hand only.This is the book not me, I hardly hear the starter motor on my major its starts so quick, In cold push in excess fuel button cranks a bit but not much. Great simple rugged engine.
LenND
07-12-2007 18:02:05
It will save a lot of wear on the starter and battery. I use mine on 900 case when needed.
bison
07-12-2007 15:36:35
you got it, makes it easyer to start in winter.
