Fordson Tractors Discussion Forum
fordson dexta wheels
deene
07-16-2007 16:40:47
well i bought the fordson i had asked about a while back it does run well needs lots of attn as it hasnt been shedded or well taken care of but has live pto and hyd and all that but need at least one wheel maybe two..it has the adjustable type with the center thin part sliding into the grooves... havent had much luck finding... any are there other rims that will fit..like 8n ford or something..thanks for the help and info
David in Wales
07-19-2007 09:15:06
 Re: fordson dexta wheels in reply to deene, 07-16-2007 16:40:47
Hi;
You can fit standard 10x28 centres & rims, the most common size on smaller tractors from Ferguson 20 & 35, MF35 & 135 etc. Cheap these days new, or find some good secondhand ones BUT make sure the edges of the rims are not rusted out or badly dented on old ones.
Set your wheel width at 56 inches (between the centre of the tyres) and your wheel centres wont protrude wider than the tyre/rim ie if the tyre goes through then the centre wont hit the door/gate post !!!
David
richardinnz
07-17-2007 03:54:03
The wheels are the same as fitted to many tractors M-F 35/135,Ford 2/3000, David Brown 770/880/780/some 885s, I.H.C. b250/275/414/434 etc. They are a common wheel should not have too much trouble finding them, be carefull of secondhand prices as companys like bare-co offer new units with tyres at competitve prices.
Don Gerber
07-16-2007 22:19:14
Hi:
I don't know where you are located, but if possible I suggest you try a Les Schwab tire center. I bought mine there locally.. no shipping and they came out and installed them on my Dexta for me, at my place. No pain no strain. Ford 8 N's or Massey Ferguson wheels will work. Good Luck Don
