Fordson Tractors Discussion Forum
fuel injector pump?
ford-s
07-28-2007 15:01:38
i have a power major that won't crank.when i got it in the man that i bought it from said that it had been 5 yrs. since it had run.he said the injectors had'gone down on it',but he is the same one who said it was a '54-'58'fmd,well it's not.it has a new gasket kit,fuel tank has been cleaned,fuel system bled to the injector pump,but can't get get fuel through tubes,air flows through tubes so they are not clogged,had injecters rebuilt,all 4 were clogged,so might it be that the injector pump may need rebuilding?any input will be appreciated.cw
morningwood
07-30-2007 07:09:29
 Re: fuel injector pump? in reply to ford-s, 07-28-2007 15:01:38
When you prime the fuel system are you seeing fuel coming out of the top of the injection pump when the bolt is out ???
Scott
