Fordson Tractors Discussion Forum
lost my shifting on FMD
Jason, NW Ontar
07-31-2007 04:07:20
I stopped while raking hay, and then tried to shift it back into gear, fought with it a moment like I always do, and then I could unfortunately move the shifter around in any direction without clunking it into gear anywhere. I let out the clutch to find I was in 1st low. The high/low still works, so all I have is 1st and 3rd. Any ideas?
thanks
tole
08-01-2007 18:41:19
 Re: lost my shifting on FMD in reply to Jason, NW Ontario, 07-31-2007 04:07:20
help
W R
07-31-2007 16:52:26
Remove the gearshift lever assembly check it and
the selectors.
tiresntracks
07-31-2007 23:19:04
 Re: lost my shifting on FMD in reply to W R, 07-31-2007 16:52:26
The lower end of the gearshift lever goes into a socket on a shaft, which operates the shifting forks that are attached to a plate on the left front side of the transmission. The gearshift doesn't go directly into the shift rails like a Dexta. I would pull the gearshift out and check and see if the ball on the gearshift came out of the socket on the shaft.
