AIR WASHER (DRY) FOR FORDSON F
RL
02-21-2000 10:51:42
No more make-shift floats, oily rags, foam rubber, or screen filters. The Purolator A14650 air cleaner(can be crossed matched to other manufacturers) fits and works better than original equipment. Designed for the Saturn automobile, this substitute is virtually undetectable. Installation is easy: Carefully clean or blast air washer cap, place tapered end of dry a/c in cap, silicone outer edge, let dry & Spray w/WD-40. GOOD LUCK! Comments welcome.
jacko ferrante
11-17-2003 04:21:17
 Re: AIR WASHER (DRY) FOR FORDSON F in reply to RL, 02-21-2000 10:51:42
dear sir,
please give me a catalog or knowledge about the air washer system for cooling and humidification including the construction and the component also the process that will happen.
Thanx alot, i'd be glad if you give me all about that.
M.Moussavi
09-13-2000 09:56:33
Dear sir,
Please send for me your catalogue and information about air conditioning(air washer) Yours sincerely M.Moussavi No91-Abuzar19-Mashadcity-IRAN Zip:91768
ADAM
02-24-2000 16:54:13
are you sticking this filter on one of the two water caps of an american air washer? if so what filters the air coming up from the air intake tube in the center of the washer? i must be missing somthing, comments????
RL
02-25-2000 18:37:32
 Re: Re: AIR WASHER (DRY) FOR FORDSON F in reply to ADAM, 02-24-2000 16:54:13
Response to Adam. When I say water washer cap, I'm refering to part no. S-702 Air Washer 'Cover'.
My appology for not being more explicit. If you take a peek at the Purolator 14650 filter you'll see exactly what I'm talking about.
Theman
02-22-2000 12:35:08
Neat idea RL. I need to do something with mine. There's a stick under the float on my Fordson to hold it up but I'm not satisfied with this arrangement. One question...what does the WD40 do? I'm guessing you spray it on the filter, but I wonder why.
RL
02-25-2000 18:26:35
 Re: Re: AIR WASHER (DRY) FOR FORDSON F in reply to Theman, 02-22-2000 12:35:08
Response to Theman, WD-40 applied to filter surface adds to the efficiency of the filter. (just a better debris trap) Have discovered some other substitutes for hard to find parts; If anyone interested.
Theman
02-26-2000 11:51:54
 Re: Re: Re: AIR WASHER (DRY) FOR FORDSON F in reply to RL, 02-25-2000 18:26:35
I'm interested. Feel free to E-mail me or post.
Stan Theman
