Fordson Tractors Discussion Forum
Push-Pull Kill switch cable
Walter Allen
09-09-2007 18:35:40
Where to buy a replacement Push-Pull kill switch cable that connects to a Simm"s injection pump? Mine looks like a cable within a cable. Also are there any Light wireing harness available for the 1960 Fordson Dexta available?
Capp
09-14-2007 18:04:17
 Re: Push-Pull Kill switch cable in reply to Walter Allen, 09-09-2007 18:35:40
I believe I used one off a 2610, or a 2600 I'm not sure, but it worked really well.
Capp
Don Gerber
09-11-2007 11:48:02
I replaced my cable using a truck manual choke cable from the local auto parts store. I then adapted a stainless steel drawer pull to use instead of the furnished knob. Looks good and works fine. I do not know of any new Dexta wiring harness available here in the states. You might still be able to find and adapt a harness from a Massey-Ferguson 35 since they share the same diesel engine.
Walter Allen
09-11-2007 12:32:32
 Re: Push-Pull Kill switch cable in reply to Don Gerber, 09-11-2007 11:48:02
Thanks for the info. I have already purchased a push pull cable but it has a solid wire core instead of a flexible inner core. just maybe I can find an outer casing large enough to house the inner core that I have and make it work. As far as the wireing harness. I will just rebuild the one I have. I"m purty good at that kind of thing. Thanks again for your imput. Walt
