Fordson Tractors Discussion Forum
Fordson Dexta loses power, dies
Springer
09-09-2007 21:19:42
Back in late June, early July, I posted this subject asking for help in solving the problem of power loss and finally dying. My problem was well received and there were a lot of excellent suggestions. My Dad replaced the little primer pump (the one just before the injector pump), replaced the diesel fuel filter element, cleaned the air breather filler and housing. Some of you suggested that we replace the fuel shutoff tap (valve) underneath the tank. The old valve outlet was chewed up where the fuel line seats inside of it. Attempts were made to seal it with teflon tape, but it looks like it could very well be the culprit. Dad has ordered, received and returned two after market valves, as they were both defective. With the valves open, you couldn"t blow air through them.
Does anyone have one of these valves that you would be willing to part with, or do you know where I might be able to get one? I believe that the original part number is 957E9189C. I would appreciate any help that you can give me. Many thanks.
Springer
DAO
09-12-2007 04:46:59
 Re: Fordson Dexta loses power, dies in reply to Springer, 09-09-2007 21:19:42
I WAS IN TRACTOR SUPPLY THE OTHER DAY AND SAW THEY HAD SEVERAL DIFFERENT VALVES FOR THE OLDER FORDS. I HAD THE SAME PROBLEM WITH THE VALVE ON MY SUPER MAJOR. SO I MADE MY OWN.I MIGHT PICK ONE UP TODAY AND PUT IT ON AND SEE HOW IT WORKS.I HADNT NOTICED ONE ON THIS SITE,AND IVE GOT LOTS OF STUFF FOR IT HERE.THATS THE BEST I CAN TELL YOU. GOOD LUCK.
Springer
09-12-2007 20:06:36
 Re: Fordson Dexta loses power, dies in reply to DAO, 09-12-2007 04:46:59
That's good news. We have one in town. I'll check them out and see what else they might have that we need. For now, I think we've got the valve problem licked. Thanks for the heads up.
Springer
