Fordson Tractors Discussion Forum
1918 fordson tractor
Melinda Marshal
11-14-2007 10:27:51
My mother has a 1918 fordson tractor. It is unusual because both of the front tires are solid metal. She is selling this tractor to a relative and would like to know if the value of this tractor is either increased or decreased, or not affected by these tires. Any information or opinion would be helpful. Thank You!
Mike Farmer
11-30-2007 06:32:24
 Re: 1918 fordson tractor in reply to Melinda Marshall, 11-14-2007 10:27:51
If they are solid cast wheels then they are most likely model N. If the have wide metal spokes with cast rims they heavy steel rims they are model F. To date your tractor the No's are: - 1917 production 0 through 259
1918 260 39979
1919 43427 88088
The noticeable anomaly is because they were being built in Co Cork at the same time and used the same numbering system. This cannot be guaranteed 100% accurate but I hope it helps MTF
rustyj
11-14-2007 16:05:33
Most, if not all, of that year Fordson tractor came equipped with steel wheels. As original equipment. I don't know if a person could get rubber tires on them, but some folks had later ones with rubber tires. But, i think they were worked up by local folks. Enterprising blacksmiths and farmers did do that at times. I don't think that should affect the price for the sale of it. And, don't let the buyer tell you it should bring down the asking price! 1918---Sheesh! Hiway trucks sent overseas with the American Expeditionary Forces (AEF) had solid rubber tires, and steel hiway wheels, depending on the make and model! This was back in 1916-18. If the tractor runs, it should be worth something better than junk price! Much better!
George D.
11-14-2007 17:13:07
 Re: 1918 Fordson Model F in reply to rustyj, 11-14-2007 16:05:33
Rusty --
I think what she means is that the tractor has the solid cast-iron wheels that belong on a Model N Fordson (made overseas in Cork, Ireland and Dagenham, England after Henry Ford cleared the decks at The Rouge plant in Detroit to make room for the production of the Model A Ford automobile beginning in 1928). The original wheels on a 1918 Model F Fordson are stamped-steel with a cast-iron hub; unfortunately, these wheels tend to rust through whenever the tractor sits in one spot for too many decades. So, some enterprising soul found a set of cast-iron wheels from a Model N and replaced the defective ones. You see this fairly often.
Since they're not "stock" equipment, that would detract a little from the value. Remember, though, that the Fordson Model F appeared on the market in the U.S. in July 1918, so if the tractor is indeed a 1918 (one would need to examine the serial number, manifold, wheel hubs, etc. rather carefully to check for 1918-specific features) it is worth a little more than the run-of-the-mill Model F's that you see all the time.
Besides, if you're selling to a relative, don't you tend to cut them a deal anyway? (Unless it's an in-law!)
That's my two cents' worth; your mileage may vary.
-- Geo. D.
rustyj
11-20-2007 08:23:58
 Re: 1918 Fordson Model F in reply to George D., 11-14-2007 17:13:07
Thanks for the up-date on the wheels. I'm not an expert on those old Fordsons (USA Made) My Grand-father had one setting in his barn for many years, Sunk into the dirt-didn't run, but us kids played on it. It had the steel wheels, near as i can remember. I think the US Air force dropped it on Germany during WW II!
cdmn
11-17-2007 20:34:45
I thought the tractor factory was raised so Henry could build his new museum on the spot.
