Fordson Tractors Discussion Forum
fordson major super id
mike jenezon
12-17-2007 09:24:43
Hi need a little help ,looking at a fordson tractor, guy says he thinks it is a super but he dosn't know for sure.
? 1 did the reg or power major have the headlights low in the grill like the super
? 2 did all supers have independent pto or is it an option this one has power steering
thanks mike
Mike Farmer
12-30-2007 11:50:14
 Re: fordson major super id in reply to mike jenezon, 12-17-2007 09:24:43
Only the serial No will give you the info you require. Live drive (dual clutch) was only available from about March 1957 probably around ser No 1422000 but that No is a guess, my list is not that specific. MTF
cdmn
12-22-2007 21:33:24
Power steering add-on was sold by Sherman Brothers.
Bendee
12-18-2007 05:12:14
My 62 super ,with live pto, does not have the tool box on the left side. Tell if its a dual clutch because clutch housing is noticeably longer. this does not appear so.My lights are outside of radiator shell,with Super Major imprinted on Front of Shell.Get serial No.
Production Jan 52 to Oct 64.No stamped on flange of flywheel housing near starter mounting.
Effective Serial 1380939 on pad at front RHS of Block.
In Nov. 61 SN was changed from 7 digits to 6 with prefix and suffix .
Note..when new system was introduced only 6 digit number was stamped on tractor ,later a "z" was stamped in front of prefix but deleted after short time..
DAO
12-18-2007 04:39:41
IF YOU GO BACK AND LOOK AT THE SERIAL # ON THE ENGINE, THE FIRST 3 #S SHOULD BE, JUST GUESSING O8B,O8C OR O8D. THAT WOULD BE 62,63,OR64 YEAR MODEL. ID GUESS A 63,JUST FOR FUN.
Bob N.Y.
12-17-2007 17:08:27
Independent PTO was NOT avaialable on Fordson Major Diesels. Some do have Live PTO by way of a 2-stage clutch.
mike jenezon
12-17-2007 18:13:28
 Re: fordson major super id in reply to Bob N.Y., 12-17-2007 17:08:27
Ok , wrong term! was the 2 stage clutch an option or standard on the super major I have read that it was an option on reg or power majors . as to getting serial # off engine wish it was feasable but it is 130 miles from me . thanks mike
Bob N.Y.
12-18-2007 17:30:41
 Re: fordson major super id in reply to mike jenezon, 12-17-2007 18:13:28
I found a sales pamphlet that says the 2-stage clutch was optional on the 1963-64 Fordson 5000 Super Major. Those were the ones with gray hoods.
DAO
12-17-2007 13:47:49
SURE LOOKS LIKE A SUPER TO ME, BEST I CAN TELL. CAN YOU GET THE SERIAL # OFF THE BLOCK,THAT WOULD HELP ALOT.
mike jenezon
12-17-2007 09:29:01
heres a pic of the tractor.
tiresntracks
12-17-2007 19:37:36
 Re: fordson major super id in reply to mike jenezon, 12-17-2007 09:29:01
Mike,
The headlights were only inside the grille on Supers. Majors and Power Majors had them on the outside of the radiator shell. All versions of the Major had the live PTO as an option. You could get any of them with or without it. Supers had disc brakes, the others had drums that stuck out through the fenders. Supers had position and draft controls for the 3-point, the others only had position control. The picture looks like a Super, if no one has changed the grille.
