Fordson Tractors Discussion Forum
fordson major tractor info.
andrew coy
01-05-2008 05:34:06
Hello. I have a fordson super major diesel 4wd tractor and i am not sure of the year and am wondering if anyone can tell me how to find out the year of it? THANKS!!
Lanse
01-14-2008 17:58:55
 H I !!! in reply to andrew coy, 01-05-2008 05:34:06
Ya know, photo adds work well for parts.
AdrianUK
01-06-2008 13:45:11
 Re: fordson major tractor info. in reply to andrew coy, 01-05-2008 05:34:06
Hi Andrew
Your number 1597730 indicates your tractor was produced in April 1961. Serial numbers for that month were 1596773 to 1601149.
It's quite an early number - production started with number 1575971 on October 24, 1960.
Best Wishes from Wales!
Andrew c in nbc
01-06-2008 15:01:56
 Re: fordson major tractor info. in reply to AdrianUK, 01-06-2008 13:45:11
Thanks..AdrianUK.Your information is very valuable to me.Regards..andrew coy.
kenneth armour
01-05-2008 17:46:19
Hi Andrew:
I am looking for two complete axles for the Front Differential for my 1963 Fordson Super Major Roadless. Would you by any chance have spares.
I am in Halifax, Nova Scotia Canada. Where are you located
Thanks
Kenneth
Mike Farmer
01-05-2008 13:22:35
Post the engine No and someone here will tell you within minutes. If in doubt about where to find it; its on a tag somewhere under the bonnet(hood) probably on the fire wall between engine and Battery and its on the engine on a flat space approx under the No1 injector MTF
andrew coy
01-05-2008 17:57:39
 Re: fordson major tractor info. in reply to Mike Farmer, 01-05-2008 13:22:35
Thanks for your reply mike. The number I found on the engine block under the injector pump as there was no tag is as follows: E1ADDN6015. Hopefully this is the correct number.
Thanks in advance,
Andrew Coy
bendee
01-05-2008 18:21:38
 Re: fordson major tractor info. in reply to andrew coy, 01-05-2008 17:57:39
That is a part number.Suppose all Fordsons are the same.
early.. flywheel housing flange near starter mounting.
Later..pad front rhs engine cylinder block.
might start with 08 then alpha letter.FWD's may be different.
Andrew c in nbc
01-06-2008 08:24:04
 Re: fordson major tractor info. in reply to bendee, 01-05-2008 18:21:38
i think that i have found the correct number i hope. it is 1597730.thanks!
