Fordson Tractors Discussion Forum
FSM Hyd. Steering Internal Part - Search
Bill_S
01-28-2008 16:00:24
In the IT manual it's the #12 part in the exploded view on pg. 12 and is called "Power ball pin cup" almost exactly 2" dia., it is the thin one, NOT the thick #9 item. Mine is broken away at the edges 2/3 way around. The power steering has been ineffective since I've had it (7 years) and that can be quite the struggle with a 6' Model 712 loader. Ford New Holland does not "service" that component any longer. Does anyone here know where to locate a used or new one? BTW, it's the later version of steering cylinder. Missing entirely was #19A retainer also not "serviced" by Ford New Holland. My adjuster nut has only one slot, not the three in the exploded view. I'm afraid even that damaged component alone would not render the power assist ineffective. Nothing else appears compromised. I welcome suggestions. Thanks, Bill
benny2
01-30-2008 08:05:25
 You may try or Re: FSM Hyd. Steering Internal Part - Search in reply to Bill_S, 01-28-2008 16:00:24
You may try Bendix that valve is made by Bendix.
Or you may try Clark Forklift they use the same valve.
The Early Ford row crop also used the same cyl and valve.
Bill_S
01-30-2008 21:55:03
 Re: You may try or Re: FSM Hyd. Steering Internal Part - Sea in reply to benny2, 01-30-2008 08:05:25
Thank you very much, that's a big boost. Bill
dwol
01-29-2008 13:06:30
Link
