Fordson Tractors Discussion Forum
1959 fordson dextra
cornbread
01-30-2008 22:40:27
im looking for the top aux hyd gasket with the o rings and also for a dealer for a rear seal in the pto shaft also changing all fluids willl rottella oil work for trans and rear? thanks in advance
native
01-31-2008 18:29:37
 Re: 1959 fordson dextra in reply to cornbread, 01-30-2008 22:40:27
The parts store on this site sells the seal, look in the upper right corner under parts and pieces. Then select dexta in the lower pulldown. You should find the PTO seal when scroll down. I've got my hydraulic system opened up now but was not able to find the gasket or the O-rings for aux hyd. I plan to reuse my gasket and I'll go to a seal store for the O-rings. Good luck.
benny2
01-31-2008 08:39:08
 Its all in the Re: 1959 fordson dextra in reply to cornbread, 01-30-2008 22:40:27
Its all in the Name, I know a lot of people call it the Dextra but it is Dexta and only till you get that right, will internet searches turn up the correct parts. Hope that helps
WayneB
02-01-2008 13:02:32
 Re: Fluids in reply to benny2, 01-31-2008 08:39:08
Fluids.
I put 134 Hyd in both my Dextas, per discussions on this forum. My Super Dexta has super tight hydraulics, and I can park it with an implement lifted, come back in two weeks and it is still lifted, same height.
Wayne
