Fordson Tractors Discussion Forum
fordson major
DONALD MACPHEE
02-21-2008 07:58:50
Where do I find the Engine Number of a Fordson Major C. 1950"s (E1ADDN 6015)
tiresntracks
02-21-2008 19:33:58
 Re: fordson major in reply to DONALD MACPHEE, 02-21-2008 07:58:50
There is a machined pad on the block under the no.1 injector. Its probably stamped there. If its an older one, it will be stamped on the flange where the engine and transmission bolt together, behind the starter. It may also be stamped on a tag on the engine side of the firewall in front of the fuel tank. The numbers are stamped, not cast, so you may have to scrape off some dirt to find them.
