Fordson Tractors Discussion Forum
water in engine oil
justin garnel
02-25-2008 13:03:12
I recently went in to Jiffy Lube to get a oil change when the guy told me he had some bad news, he said he noticed I had some water in my oil. It kind of looked like some green slim. He said its possibly my head gasket. Is he right and can it be something else?
Walter Buller
02-25-2008 20:49:35
 Re: water in engine oil in reply to justin garnel, 02-25-2008 13:03:12
I have cured a number of cases of oil in colant water as well as water in crankcase oil with K&W BLOCK SEAL, or a similar product that takes 24 hours for the whole process. These were permanent cures.
Ebbsspeed
02-25-2008 14:35:31
Green slime would indicate that there is some anti-freeze getting into your oil, either through a bad head gasket, or a cracked block or head. Or if it's a tractor with cylinder sleeves it could be a bad sleeve seal. Or if it's a John Deere 2 cylinder it could be bad pushrod tubes. But then again, if it's a tractor you're probably not getting the oil changed at Jiffy Lube.
What kind of vehicle?
