Fordson Tractors Discussion Forum
Where do I fill the back hydraulic reservoir?
Dave Middleton
03-11-2008 18:36:23
Howdy, I learned from Native that my Fordson Dexta as two resevoirs for hydraulic oil/transmission oil. Can anyone tell me where I fill the differential? The transmission has an obvious filler, but not the differential.
Bruce Hopf
03-13-2008 17:57:25
 Re: Where do I fill the back hydraulic reservoir? in reply to Dave Middleton, 03-11-2008 18:36:23
Dave
Like jimont said the fill plug is on the rear end housing just behind the drivers seat. The oil level indicator, is located inbetween the PTO shift leaver, and where the clutch pedal attatches to the transmission housing. there is a small plug there to remove with a 7/16 wrench. Fill the resevoir until oil starts to run out, then put the plug back in. Any more questions, will try to help.
Bruce
jimont
03-12-2008 06:53:06
Dave - Plug is to the right of the seat on top of the rear end. Takes a 15/16" wrench if my memory is corrrect. Uses 134 oil as well.
