Fordson Tractors Discussion Forum
Ford-Fordson, Supermajor-Powermajor any difference?
Bernhard
03-13-2008 22:14:58
I´m not a Ford Specialist, even as we have had a very busy Ford Dealer here since more then 45 years. We have had some Supermajors in early 60`and a 4000 Supermajor ran in neighbour village around 1966.
Is there a difference between Supermajor and Powermajor? Are they both built in UK? Cause I don´t think that the Gent plant was Ford at the days of the Supermajor. Gent should be the Claeys Combine Plant.
From look of things US has Ford and Fordson in the 50 th. for what reason?
woodache
03-14-2008 10:55:41
 All Majors are Re:Ford-Fordson, Supermajor-Powermajor in reply to Bernhard, 03-13-2008 22:14:58
All versions, till 1964, of Fordson Majors are English! The super Major has many differences than the other models. Mostly Trans, rear axles, and Hyd lifts. Some changes in the engines too.
ford-s
03-14-2008 10:48:38
 Re: Ford-Fordson, Supermajor-Powermajor any difference? in reply to Bernhard, 03-13-2008 22:14:58
I own a '60 power major,and a '61 super major.my p/m is about 6 inches shorter than my s/m.both of mine came with 3 pth,as I read in the manual,the p/m was built in '59&'60 it was a precurser of the s/m.The big difference in the two are the hydraulic lift control,the p/m is almost under the right knee,while the p/m is on the right side.The s/m was built from '60-'64,then it was replaced by the ford 5000.hope it helps,cw
steve ont
03-14-2008 09:47:42
not an expert either but have a '48 with 3pth on it power major was the series before the supers. built in the UK
farmerdon
03-14-2008 09:11:06
I'm not a Ford expert either but in the early 50's the Fordson was imported from England gas model was blue and diesel model was gray----much higher horsepower and no 3 point hitch as compared to the Ford models made in the USA.
