Fordson Tractors Discussion Forum
Horsepower
David allen
03-28-2008 19:21:30
Well I have another question!
What is draft control?
Also my 64 Dexta has a double clutch but is it a wet clutch?
Every time I start the tractor it spits Hyd. oil from the inspection hole at the flywheel.
Seems like their should a gasket at the ispect. hole if clutch is wet but tractor pulls great!
David allen
03-31-2008 12:15:00
 Plenty of Work to do in reply to David allen, 03-28-2008 19:21:30
Thanks for all the Information! I finally have the tractor at my place and getting ready to split case. Fluid is definatly hyd. Hey Bruce Hopf you said you have a Dexta but not a super! Does somthing make you thank mine is a super? I've been looking for s/n where you all said but have found nothing so far. Also some one said something about an auto part # for the breather hose that will fit this tractor? Anyway THANKS again!
Bruce Hopf
03-30-2008 22:23:44
 Re: Horsepower in reply to David allen, 03-28-2008 19:21:30
That could be engine oil. The rear engine oil seals I found are notorious for leaking. I have a 1962 Dexta, not the Super, and it leaks. Some day I will have to split the tractor, and replace it. Hope this helps. The draft control, is to help pull the plow in, if it goes up on its own, when you pull the lever up, and when you push it down, it lifts the plow up a little if it sucks in too deep. Great little tractor. Around 38 to 40 Horse Power.
Les Fenwick
03-29-2008 11:53:04
David,
May stand corrected on this but... 'draft control' is for using something like a 3 point hitch plow.
When plowing and the rear wheels start to slip, the back end of the tractor will settle down a bit which puts some pressure on the top link of the 3-point hitch.
This activates a hydraulic valve inside the rear housing that lifts the rear arms and the implement up out of the ground a bit so there is less load to pull.
After it's through the tough spot the arms and implement will return to their original postion.
Cheers,
Les
benny2
03-29-2008 05:10:26
 Clutches are Re: Horsepower in reply to David allen, 03-28-2008 19:21:30
Clutches are dry running! You have a seal leaking oil somewhere. There should be a small hole in the bottom of the bell housing for any oil to drip out. This much oil in the clutches will ruin them. If you are talking about the covered hole on the left side of the flywheel housing this is the engine timing alignment hole. No oil should come from there with NO gasket,
