Fordson Tractors Discussion Forum
faulty voltage regulator?
botchit
04-03-2008 11:50:55
Sorry guys a very simple one this..... ....having trouble starting my Dexta. On depressing the starter handle I get just a click. Previously renewed the volatge reg. Is it likely to be this again or the starter motor? Battery is fine. Anyone else experienced this?
Dandy Dave
04-04-2008 13:27:39
 Re: faulty voltage regulator? in reply to botchit, 04-03-2008 11:50:55
Also make sure that you battery and starter cable connections are clean and in good condition. :D Dandy Dave!
Bruce Hopf
04-03-2008 19:55:16
Did you check the solinoid. It could be that. Are all your connections tight. A lose connection could cause problems as well. Take a wire, with both ends clean, and touch the solinoid on both ends with the starter handle down. If the tractor starts, then it is the solinoid.
