Dexta Petrol gear selector
gerryg
04-13-2008 05:31:51
Hi All: My Fordson petrol Dexta stays in 1st gear even though the stick is in the crossbar of the H and will not move anywhere but side-ways. Is this a problem with the business end of the stick or the transmission itself? Replies appreciated.
cheers
gerry
Bruce Hopf
04-26-2008 20:00:08
 Re: Dexta Petrol gear selector in reply to gerryg, 04-13-2008 05:31:51
I have a Fordson Dexta Diesel, a 62, and I also had this problem. I took the gear shift selector, stuck it in the vice, and welded all the away around the end. I then took my angle grinder and smoothed it out even around it. I've never had that problem since. Becarfull not to get it too hot, when you weld it.
Hope this helps.
Bruce.
BOBWA
04-17-2008 07:41:42
Hi,Gerry, I'm the guy who owns a gas dexta like yours. I have the same problem.If I don't shift accurately to the "H" pattern,it jambs in gear. I have to remove the shifter and re-center the slides & shifter. Can you help me find a head gasket for that engine?? So far,,it's like hunting for a rear strut assembly on a 2078 alien spaceship! Please,,ANY comments,,
BOB
gerryg
04-17-2008 10:53:49
 Re: Dexta Petrol gear selector in reply to BOBWA, 04-17-2008 07:41:42
Hi Bob
Thanks for the reply,anyone else have this experience? No idea where you can get a head gasket. Is it not possible to buy generic gasket material and make one? Don"t know for sure just a guess.
cheers
gerry
