Fordson Tractors Discussion Forum
S/N's
David allen
04-15-2008 20:41:42
HEY! Well I finally found the S/N on my tractor.
957E85796 witch tells me I thank I have a June 6 1961 Dexta. The Engine # is 1487105 and the casting # on right side of clutch housing is H6F. Please someone tell me if I got it right. Thanks David Allen
Les Fenwick
04-15-2008 22:16:38
 Re: S/N's in reply to David allen, 04-15-2008 20:41:42
Hi David,
You have it right!
The clutch housing was cast June 6 1961.
From some charts I have seen the serial number (957E 85796) indicates a mid to late June assembly date which fits with the casting date.
There are more casting dates on other components (back of the rear axle housings, gearbox housing, rear differential and it's cover) which may help to narrow the build date.
The engine number also generally fits with a mid 1961 build.
There is an engine date code cast below and a bit to the back of the engine serial number that gives the date the block was cast.
It will be in a letter(month)/number (day)/ number(year) format.
Cheers,
Les
