Fordson Tractors Discussion Forum
TO KBRUTON,,timing mark.
BOBWA
05-05-2008 14:29:09
I THINK YOU FOUND IT.THAT'S WHERE MINE WAS,,ON THE FLYWHEEL TO THE LEFT OF THE RING TEETH.LOOK THROUGH THE SIGHT HOLE WITH A GOOD FLASHLIGHT.LET ME KNOW IF YOU FOUND IT,,,O.K.?
BOBWA.
Stefan from Germany
05-11-2008 02:20:15
 Re: TO KBRUTON,,timing mark. in reply to BOBWA, 05-05-2008 14:29:09
KBRUTON seems to pasted away ....
KBruton
05-17-2008 21:01:39
 Re: TO KBRUTON,,timing mark. in reply to Stefan from Germany, 05-11-2008 02:20:15
Yep, had to use a flashlight to find the timing mark in the access hole. It was real hard to see though. Sorry about the late reply, I had to stop working on the thing for a bit due to the urge to disassemble the entire motor before the mark was found. Now I"m back to my original problem, engine keeps dying due to air in the line. Talk about bum luck... After bleeding the line for the hundredth time, I snapped off one of the bleed screws in the injector pump. No worries though, I made another from an exact match (no hole though) bolt I found at the local hardware store and drilled in some passageways to mimic the bleeder screw.
