Fordson Tractors Discussion Forum
FSM Lift
D. Moye
05-16-2008 07:11:48
I have been reading the posts on this tractor. I just got one and the lift arms will not raise or lower when I move the quadrant. I have seen many posts who seem to have this same problem, but do not seem concerned about it. This tractor set up for many years and when I got it had no oil in the trans. or rear end. It had a brush guard on it like people around here use to mow pecan groves and I think that was what it did most of it's life. I this an easy fix, or do I have problems. This is my first FSM and it runs like a charm, but it is no good to me without a 3-pt. hitch. Thanks, Moye
Bruce Hopf
05-19-2008 04:47:10
 Re: FSM Lift in reply to D. Moye, 05-16-2008 07:11:48
D. Moye
Check to see if the PTO works. If the PTO does not work, then you have to engage it by pulling the lever that is beside the clutch petal back towards the seat. This engages the hydraulic pump, as well as the PTO. If the PTO does work, e-mail me, and I will help you. I have a FSM, as well. I grew up with this tractor, and know it inside and out, and I have a shop manual as well. My Late Father owned it since 1974, and I have owned it since 1998, when he died. I will be real happy to help you.
My e-mail address is posted, and is always open. Bruce.
