Fordson Tractors Discussion Forum
dexta lift height adjustment
Bruce Hopf
05-19-2008 05:03:37
Native
When you have your bush hog off the tractor, does the hydraulic arm go all the way up. If so, it is not your hydraulics that are the problem, but your top link is way out to long. Remove the Top link, on a level surface, and lift the front of the bush hog up. Using a tape measure, measure from the ground to the bottom edge of the bush hog, at the rear, and have the front the same height, as the back of the bush hog. reinstall the top link, and make adjustments to the top link to fit. You must have these machines level to do a good job. If this is not the case, and then I will check with my shop manual, to see what your trouble is.
E-mail me and let me know if this helps, or not. I will be more than happy to help you.
Bruce.
Native
05-19-2008 16:26:43
 Re: dexta lift height adjustment in reply to Bruce Hopf, 05-19-2008 05:03:37
Hi Bruce, thank-you for your response. My top link is turned all the way in and I can still barely get the wheel on the back of the mower to lift off the ground. It used to lift higher than it does now, apparently I somehow changed one of the adjustments when I had the lift assembly off this past winter. I thought I put everything back together correctly, but obviously something has changed. The manual shows how to make adjustments with the whole lift assembly placed in a vice. I briefly read through the procedure and stopped when they referred to special tools that would have to be modified( I believe tha manual said they were for a Ford 8N or 9N? ). I took it apart because the lift height control had started to sieze-up due to lack of lubrication in the upper moving parts and deteriorated seals allowing moisture to seep in and cause them to start rusting. If you or anyone else knows how to make this adjustment without the special tools which I'm fairly sure can no longer aquired, that information would be greatly appreciated. PS: The lift lever works like new now( no resistance ). Thanks again
