Fordson Tractors Discussion Forum
Power Major?
Bernie Perry
05-19-2008 10:01:14
4.157.59.104
15628
I purchased a major and was told it was believed to be a 1960, gas job. It appears that the engine may have been replaced. The serial # on the engine is S460553 or 8460553 and on the bottom of the block on same side there is a number EIADDN6015 G which I believe is a part #. On the fire wall, engine side, center top a small rectangle plate with the # 1250947 stamped on it.
maxpower
05-20-2008 09:48:58
 Re: Power Major? in reply to Bernie Perry, 05-19-2008 10:01:14
1953
Mike Farmer
05-20-2008 09:39:31
My book says February 1953 and that makes it a Fordson Major Deisel not a power major. Let me get around all the million other things and I'll post all the major numbers up to 1961 MTF
1979 powermajor
05-20-2008 17:19:51
 Re: Power Major? in reply to Mike Farmer, 05-20-2008 09:39:31
how about a 1979 power major,, must be one of a kind on ebay right now, gotta get my hands on this one,
tiresntracks
05-19-2008 20:24:16
Bernie,
You're right, an engine with an S serial number is a replacement engine. Your serial number from the plate on the firewall is earlier than 1960, probably closer to '52. I don't have a serial number book, but someone else reading this probably can tell you exactly when it was made.
