What do i i set the timing to on a 62 super major diesel?
ben
03-21-2000 20:53:11
What should i set the timing too on my 62 super major deisel?
Brian
03-22-2000 10:11:26
 Re: what do i i set the timing to on a 62 super major diesel? in reply to ben, 03-21-2000 20:53:11
Ben,
23 degrees if fitted with a vaccum governed and 21 degrees if fitted with a Minimec. Make sure the pump marks line up when the drive coupling clamp bolt is at the bottom of its travel or you could be 180 degrees out when putting the pump back on.
regards
Brian
ben
03-22-2000 19:05:02
 Re: Re: what do i i set the timing to on a 62 super major diesel? in reply to Brian, 03-22-2000 10:11:26
hey thanks!!
