Oils
John-Paul (Finl
03-23-2000 01:08:41
Hello all,
My local agricultural supply store sells something they call "Universal Farm Oil". This is a 10-30 multigrade, and they say it can be used in engines, gearboxes, axles and hydraulics.
Can I really use this stuff everywhere in my Fordson Power Major? Perhaps this could be an inexpensive way of replacing the thing's oil before I move it for the first time?
Many thanks,
J-P
Karl
03-23-2000 12:33:37
 Re: Oils in reply to John-Paul (Finland), 03-23-2000 01:08:41
Hi,
I wouldn't do it myself as temporary solutions have a way of becoming longer term than you want them to. What does the oil that is currently in it look like? When you run the tractor, does it develop any milky froth on either dipstick? If not, I would just top up the engine and the rear end with the appropriate oils (15W40 for the engine, and see your Ford New Holland dealer for the rear end), and run 'er home. Also remember to check your coolant, and see that there is oil in the air cleaner. Be sure that you have enough fuel, as you won't dig bleeding it (very messy). If you are concerned that there might be water in the fuel tank, either drain it and start new, or add some demoistureizing product to the fuel. Be sure that the product does not compromise the lubricating quality of the diesel.
Remember, these are tough little tractors. As long as they have fuel, oil, and coolant, and as long as they run, don't be afraid to run them.
Above all, NEVER use ether to start it!!
Karl
Oscar
03-23-2000 22:31:25
 Re: Re: Oils in reply to Karl, 03-23-2000 12:33:37
Good advice! It's your tractor now, don't settle for second best. And like Karl said, for heaven's sake don't use ether!
Best of luck with moving the tractor; let us know how it turned out!
Ron N
03-26-2000 18:50:12
 Re: Re: Re: Oils in reply to Oscar, 03-23-2000 22:31:25
I have a Fordson Major Diesel and it will not start without a shot of ether. I saw that Karl and Oscar advised never using ether to start. Can anyone explain why? I've been doing this for eight years without a noticeable problem.
Oscar
03-26-2000 21:44:52
 Re: Re: Re: Re: Oils in reply to Ron N, 03-26-2000 18:50:12
An engine only needs fuel, air, coolant, oil and a good battery to get it running and keep it running. If it doesn't, something's wrong with it. Using ether won't fix that; it'll only get a faulty engine started, while instead you should have it checked and fixed. Even worse, ether is likely to damage the engine. I have two cracked pistons sitting at home as proof of that (the previous owner also liked ether very much). After starting using ether, there's no way an engine's going to start without it, even in summer.
To summarize, don't fight the symptoms (with ether), but solve the underlying problem instead.
