Hydraulic system
R.Clark
03-24-2000 02:07:28
Still having trouble with hydraulic lift. Oil has been changed, filter cleaned. Lift will move about half way up. Does anyone have a suggestion that might help with this problem? We are using 80-90 hydraulic oil.
Briggs
03-24-2000 12:49:52
 Re: hydraulic system in reply to R.Clark, 03-24-2000 02:07:28
I had a problem with my Dextra's lift. It would only raise half way. The problem was inside the lift cover. I bought a T0-20 service manuel. I pulled the lift cover off and chucked in vise. Made adjustments just as it said. The back-up nut on the draft arm linkage had backed off. It could have been wooking loose for years. With this linkage properly adjusted the lift works fine. I live in central TX.,and this little tractor is a little odd looking. But nothing can hold a lite to it. It's a great tractor. Remember lock down the back-up nut, before reinstalling.
