Super Major lift arms
john s
03-29-2000 08:50:03
My hydraulic lift is erratic--it has good power, then sometimes it won't respond at all. It has
sufficient fluid and the remotes are functional so I don't doubt the pump. Do you think it needs o rings in the selector valve or what else?
brian
04-01-2000 09:16:16
 Re: Super Major lift arms in reply to john s, 03-29-2000 08:50:03
John,
Normally,if you had a leak, like faulty "O" ring seals, your problem would be there all the time. Sounds like you have sticking valves in either the ram cylinder or the flow control valves in the auxillary service chest on top of the lift, just in front of the seat. How often do you use the tractor? and what are you doing with it? The more information you can give us, the more accurate our diagnosis.
regards
Brian
john
04-10-2000 06:41:05
 Re: Re: Super Major lift arms in reply to brian, 04-01-2000 09:16:16
Thanks for the response. The tractor has been
sitting for a long time before I got it. I am putting a ford 712 front loader on it (powered by a separate pump) and will need to have the lift arms working so they can support a counter-weight. I am going to be using the tractor a lot on the farm. Thanks again guys.
john
