Progress report, and lots more questions... (long, no pictures :-)
John-Paul (Finl
04-11-2000 04:05:43
Hi all,
Greetings from the Frozen North. The ..er.. "Major" news now is that for the first time in over five years my tractor has a change of view - I've turned it around!
Yesterday I discovered that despite my earlier conviction that the cooling system was empty, it has in fact been full of anti-freeze the whole time. I squeezed the lower radiator hose, and green stuff became visible in the filler neck. The time had obviously come for a proper run of the engine, so, forgetting Brian's advice about disengaging the PTO (no oil showing on back axle dipstick), I started it up. As the electrics are basically non-existant I have developed a procedure whereby I attach a jump lead from my car's battery to the tractor frame, raise the decompression lever, press the starter lever, then connect the other jump lead to the terminal on the back of the starter. The engine then starts to crank over. With my cheek pressed against the exhaust stack, I can then make a lunge across the front of the engine with my left hand, and lower the compression lever. The engine starts, and I let go of the starter lever, and disconnect the jump leads from the starter. Not exactly how Mr Ford planned it but anyway it works. If I don't use the decompression lever, my jump leads start to fume.
After ensuring that there were no obvious problems, I let the thing tick over happily while I set to work chipping the wheels out of the ice. That took I suppose about half an hour, then after jacking the front wheels up out of the depressions thay had made, and filling in underneath with sand... I drove the tractor forward, and turned it around so that I would have better access to the rear axle. After generally admiring it for another ten minutes or so it suddenly hit me that I had left the pto/hydraulic pump engaged, and I had assumed that the rear axle had no oil in it at all! There seemed to be nothing to do, except try that little handle to the right of the seat. I lifted it... and... the arms raised, thereby proving both the existance of oil in the axle, and the existance of God.
This leads me on to this weeks quiz:
1. The arms raised and stayed up, but the drag link arms spring up and down if I jump on them. Is this normal? (15 points)
2. What size /thread bolt to I need to secure the little plate that covers the hole in the bellhousing where you can inspect the timing marks on the flywheel? (20 points)
3. Where the steering radius arms meet, they are attached to the tractor by a bolt rather than a pin as shown in the manual. Is this.. A. a variant, or B. a 'field repair'? If A, what size nut should it be (it's missing). (5 points, 15 if thread size known)
3b. (For extra credit) What size / thread are the sump bolts? This is not so important as I can take one of the remaining ones to a shop for comparison. (5 points)
4. The front axle seems very 'floppy' to me - it wobbled a lot when moving the machine for the first time. Is this a worry? (10 points)
5. On the right hand side of the rear axle, the grease fitting that is used to lubricate the outer bearing is missing, and the hole is full of gritty, oily mud. Any suggestions as to how to deal with this? (50 points, unless answer involves removing bearing, then 1 point)
6. Underneath the rear axle in the middle is a drain plug, fitted to a removable plate which is in turn fitted to a larger removable plate. I noticed in a post of Brian's that there is a filter hiding behind here somewhere. Is it just the inner plate (held on by four bolts) that I remove?
(5 points)
6b. When I remove the final bolt holding on the plate in 6. above, will I be surprised and / or squashed by something really heavy that I didn't intend to remove?
(5 points)
6c. What is the filter like?
(10 points)
7. Again looking under the rear of the tractor, about a foot in front of where the oil drain is, is a place on the casting where it looks like something has been or could be bolted. What is this? Should there be something here? Is this something to worry about?
(10 points)
8. Do I worry too much?
(1 point)
9. Exactly what colour orange should the wheels be? (ONLY KIDDING!)
Thanks, and regards to you all,
J-P
Brian
04-12-2000 07:33:07
 Re: Progress report, and lots more questions... (long, no pictures :-) in reply to John-Paul (Finland), 04-11-2000 04:05:43
John-Paul,
1.Sounds like your axle is not as full as you thought and you have air in the system. This will correct itself when you add more oil. (and pray that you have not damaged the pump).
2.5/16 x 3/4 ANC.
3. Should be a pin with a grease nipple on top so suspect "B"
3b. Same as 2 only longer.
4. Not right now but will need some new bushes and some building up of pins etc.
5.Clean out hole. Fit new nipple. Grease.
6.a,b,c. The middle four bolts hold the filter.
Lots of oil! Oops forgot to drain axle. Then just a plate with a mesh type filter to clean. There are also two bolts just in front of the plate. These are magnetic and trap any metal particles immediately in front of the pump intake. The larger plate holds the pump. (See below 10).
7.Have you got a drawbar fitted. This sounds like the place where the front drawbar piviot bolts.
8.No but don't forget, these tractors were built very strongly. When they were replaced by the 5000 series Fords saved nearly 5cwt in weight on a higher HP tractor, and the 5000 was not very flimsy. I have mentioned in an earlier post to Oscar that I have come across a Major rear end fitted to a Rolls-Royce Merlin giving nearly 1200hp through the unmodified Major parts.
9.Howard Rotovator Orange.
and, Oh yes the one you did not ask. 10.About £800. (The cost of a new hydraulic pump, the only part liable to lack of oil damage in the rear axle). :(
regards
Brian
Joe Smith
04-29-2005 08:03:09
 META HTTP-EQUIV=Refresh CONTENT= in reply to Brian, 04-12-2000 07:33:07
<a href=http://ass.matures-stories.com/>ass matures</a>
Brian
04-12-2000 11:05:00
 Re: Re: Progress report, and lots more questions... (long, no pictures :-) in reply to Brian, 04-12-2000 07:33:07
Oops,
Deduct marks for 2. Should read UNC. Unified National Coarse.
Brian
Oscar
04-11-2000 22:27:30
J-P, great post! I can't answer most of your question, as I don't have a Major myself. As for question no. 7 however, I suspect that's where the swinging drawbar should be attached.
Best of luck with the restauration. Hopefully some of the others will be able to help you with the other questions.
john
04-12-2000 09:13:40
 Re: Re: Progress report, and lots more questions... (long, no pictures :-) in reply to Oscar, 04-11-2000 22:27:30
Where can we get Howard Rotovator Orange in the US? If not is there another available orange on the shelf?
Brian
04-12-2000 11:00:35
 Re: Re: Re: Progress report, and lots more questions... (long, no pictures :-) in reply to john, 04-12-2000 09:13:40
John,
The next best orange is the Fiat one available from CNH dealers.This seems to be the one most reccomend. Allis orange is similar to Rotovator orange and is perhaps "brighter". The FMD and Super were very colourfull. I personally like the colour scheme of the Super 5000. The cream bonnet and blue castwork look great.
regards,
Brian
john
04-13-2000 06:53:38
 Re: Re: Re: Re: Progress report, and lots more questions... (long, no pictures :-) in reply to Brian, 04-12-2000 11:00:35
Brian
I don't recognize the CNH name, I'll have to track it down somehow. I liked the 5000 SM--I restored one a few years ago which I found in pieces for $475. I never could find the decal though. When my wife was in Ireland I told her to try to find one at a dealer there. She came home with a decal for a regular Ford 5000, which I used as an excuse to buy one of them to fix, after selling the Fordson 5000. I called it fate, now if I could just find the name plate for a Porsche...
By the way what's the best way to restore a Super Major chrome badge once it's pitted?
Paintwise I am puzzled by my latest Super Major's paint. It's all blue as I expected but the wheels are a kind of silvery gray brown (almost a massey furguson silver brown) Has some one repainted them? They are orange underneath but most of the tractor is primed that way too.
I'm looking forward to cleaning it up and painting it in my Easter holiday from teaching school.
Fordsons Forever!
John
Brian
04-13-2000 09:27:06
 Re: Re: Re: Re: Re: Progress report, and lots more questions... (long, no pictures :-) in reply to john, 04-13-2000 06:53:38
John,
Sorry, CNH = Case New Holland, the people who now have ownership of the Ford Tractor business.
I am afraid the only way I know to redo the badge is a complete re-crome.
Regarding the wheels, sounds like someone has repainted them. The orange colour underneath could be a red lead primer as most of the tractors got a good coat of that. All the inside of the lift, gearbox and engine as well.
regards
Brian
