Super major diesel must not exist
todd
04-11-2000 15:58:09
i've been trying to find out any info good or bad about the unit, they must be very rare or not exist at all.
Bart
06-26-2000 14:48:01
 Re: super major diesel must not exist in reply to todd, 04-11-2000 15:58:09
Hello
This is my first time on this site.
I am looking for a electricwire diagram for a Fordson Super Major. A friend of mine have electric problems. The tractor does not start.
Could anyone send me some?
Greetings
Bart
ccrfan@introweb.nl
The Netherlands
Bart
06-26-2000 14:47:08
Hello
Greetings
Bart
ccrfan@introweb.nl
The Netherlands
Steven B
04-11-2000 17:52:14
The Super Major was the last in the of E1A series of tractors produced from 1951 to 1964 at Dagenham, England. I do not know the actual figures but I would guess that 99% of Super Majors were Diesel. There were no TVO or Kerosene versions, There was a Petrol version but they are rare. They were produced in such quantities that towards the end of production, over 300 were being made each day.
There are three variants of the Super Major. Released in 1960, the tractor had the following changes when the Power Major was superceded:
Disc Brakes
Diff Lock
Position Control/Qualitrol hydraulics
Strenthend differential
Changed styling on front cross member.
Fenders/wings modified for disc brakes.
Head lights moved into grill on UK market.
Horazontal bars on grill for export market.
Changed badging
In 1962, the Simms injector pump was replaced by a Minimec unit (this still has simms on the casting). This injector pump has a mechanical govenor instead of the pneumatic type of the previous model. This change gave a slight horse power increase from 52 to 54.
In 1963 the "New Performance" Super Major was introduced. This model was the last E1A Major's and the most visible change was the colour, instead of light blue with orange wheels, it was light blue with grey fenders, wheels and seat. Also the chrome "Fordson SUPER MAJOR" badge was replaced by a blue and silver "FORDSON" decal and the badge on the front had grey letters. The front wheels were changed to steel from cast on the UK market in line with some export tractors. Some of these tractors were badged as "FORD 5000 Super Major" with a grey bonnet/hood in the USA. The major mechanical improvements with this model are:
Changed gearbox and diff ratios.
Drop control for the three point linkage.
New hydraulic pump with increased flow.
Improved swirl on the intake ports, the cylinder head being identified with the leters "FL" cast near number one injector.
All of these tracors are first class. They are built like an Iowa class battleship. There are a number of options that are highly desireable. Live PTO is top of my list, then the Raised PTO. The raised PTO allows you to disengage a mower but still use the hydraulics. lastly, power steering. The steering on the majors is not to heavy but if you have a front end loader, this is a must have.
These tractors are reliable, easy to start, stong pullers, easy to work on, economical, parts are readely available, and, all in all, one of the best tractors in the world. I have a late 62 Super Major, and I love it.
steven_barker@westsig.com.au
todd
04-12-2000 15:48:58
 Re: Re: super major diesel must not exist in reply to Steven B, 04-11-2000 17:52:14
thanks a whole bunch for all the info,its a 1964 i'm thinking of going to look at, i just wanted some info before i took the trip thanks again, todd
Brian
04-12-2000 06:50:54
Steven,
Great writeup!! Did you ever sell them:)
Seriously though they are an excellent tractor and hold their price. The problem I have is identifying from the posts in other pages on this site, which is a Super 5000 and which is a 5000,5000 if you get my meaning.
regards Brian
Steven B(Question for Brian)
04-12-2000 17:40:00
 Re: Re: Re: super major diesel must not exist in reply to Brian, 04-12-2000 06:50:54
Brian
I also got confused at first with the "Super Major 5000". I always thought they meant the 1965 Ford 5000 Super Major. BTW, I picked up a mint 1965 sales book the other day for $5.00. It coverd the first of the world series 2/3/4/5000 tractors. I had a 1969 5000 with the Selecto speed transmission. What do you think to this model?
Steven
Brian
04-13-2000 02:13:03
 Re: Re: Re: Re: super major diesel must not exist in reply to Steven B(Question for Brian), 04-12-2000 17:40:00
Steven,
Most of the time TROUBLE. It depends whether you liked them or not. We regularly, every two years, sold 25 to a large farming company who farm in Norfolk, (of Netherland origin Oscar) who loved them. Most of the modern transmissions have their roots in selectospeed, but they were too early and customers would not accept them.
The modern John Deere is held up in this area as the best you can buy and people seem to have not noticed that it has the same big jerks as you change range.
One mistake Ford made was to demonstrate how easy it was to change from high speed to reverse. This was a feature at all demonstrations of the tractors. Unfortunately they forgot that things are different with a 10 ton trailer behind.
I liked them on pto work or ploughing but found the reliability suspect if worked hard and subject to normal farmer maintainance.
We had one customer however, who ploughed with three furrows, in heavy blue clay that could only be ploughed it the wet, on steel wheels, for years with no trouble at all.
regards
Brian
Steven B
04-13-2000 20:57:46
 Re: Re: Re: Re: Re: super major diesel must not exist in reply to Brian, 04-13-2000 02:13:03
Brian
Why did I know you would say that? That "inching pedal" should have been called a "footing pedal", With a four furrow plough on it, or worse, a mounted 9 foot offset disc, it was hard to keep the front wheels on the ground. My tractor had been fitted with a turbo at the Ford dealers from new. It was about 90hp. The selecto speed was great for maintining a steady work in changeing drakt loads. Way ahead of its time.
Regards
Steven
todd
04-12-2000 15:52:58
sorry about the post, i've put up a few posts that just said super major diesel and no one replied, guess i know how to get your attention now!! thanks
john
04-12-2000 06:46:49
You can't beat a Super Major or a 5000 Super Major as a mid sized tractor. They are very
economical to run and it is not hard to get parts despite what some people think.
People that have them love them.
todd
04-12-2000 15:54:57
 Re: Re: Re: super major diesel must not exist in reply to john, 04-12-2000 06:46:49
thanks for all the great info, i now know that its a good tractor , thanks guys
