Timing a 1936 English Fordson
ken
04-11-2000 20:17:04
I have been working on a 1936 English Fordson and had to remove the magneto to reweld the mounting plate. Unfortunately, I also removed the mounting plate to have it fixed and then realized that somehow I need to realign the gears. I can put #1 cylinder to "top" and then make sure that the coupling on the govenor points vertical so that the magneto coupling would then be horizontal. I could be a few teeth off though on the gear alignment. Is there another way to do this?
