Fordson major injector pump
bob black
06-26-1999 06:51:18
I'm looking at buying a fordson major with an injector pump that the owner claims needs rebuilding. I have a small machine shop and would like to rebuild it myself. Any info on how-to, rebuild kits, etc. would help me decide which way to go.
Jim
09-06-1999 15:37:08
 Re: fordson major injector pump in reply to bob black, 06-26-1999 06:51:18
a few questions are in order. first there were two different style pumps used. one is air governed and will have air lines running from the intake manifold to the pump. and the other is mechanical the mechanical pumps were only used on the later super majors so i assume you have the air governed pump and i do have one that does not need much work i swapped on a mechanical goverened pump. the problem with rebuilding the injection pumps is that to properly do the job you should have a test machine that the fuel shops have. without the test machine you cannot tell how much fuel you are getting and where the governer speeds are set and how well the pump is functioning.
bill
01-02-2001 11:03:03
 Re: Re: fordson major injector pump in reply to Jim, 09-06-1999 15:37:08
i want to rebuild but cannot find any kind of print or picture of the pump . any suggestions!
