Simms Pump noise
Dann Parker
04-15-2000 22:34:29
I am looking at buying a 57 or 58 Major. It seems to run well and pull hard, but the injection pump was making a clicking sound that was as loud if not louder than the engine itself. Since I haven't heard one of these run before, is this normal?
Thanks,
Dann Parker
John
04-23-2000 20:55:07
 Re: Simms Pump noise in reply to Dann Parker, 04-15-2000 22:34:29
Another note on this coupling. I once had to change the metal part on the side where the bolts go through. One side broke out around the bolt head and the timing slipped way back to where the tractor wouldn't hardly run and blew white smoke. Couldn't figure it out for a while what was going on. As a temporary fix, we cut pieces of steel post anchor to put under the bolts and that ran fine for a year or so until I got the new part installed. Also had to change the drive shaft from the engine as it got bent in this process.
Bill in Mich
04-16-2000 20:21:46
These guys are right. Its your drive coupler. Mine did the same thing. When I found out what it cost to replace the two coupler halves and the fibre insert I drove shims into the coupler to tighten it up then wrapped it with 3m electrical tape to hold them in place. I know it sounds crude but my tractor ran for a long time that way.If you do opt to change the parts, its a good way to isolate the noise first to make sure that another prob is not present, Bill
Brian
04-16-2000 00:47:12
Dann,
Helton is correct. It is the fibre drive coupling. These can be tightened a little by slackening the clamp bolt on the engine side and levering that half of the coupling towards the pump.
Regards
Brian
Helton
04-15-2000 23:20:27
I'll be interested to hear the replies, mine does the same thing.But I'm pretty sure it's just the exterior coupling driven by the pump.Check you later.(North Carolina)
Helton
04-15-2000 22:50:13
