Need parts for super dexta
Chip
04-22-2000 23:42:24
I have recently purchased a super dexta with a 142 diesel (english made) and its got a lot of slack in the steering and is HARD to steer. Where can I get parts to rebuild it. I have other questions about this tractor, please any info would be greatly appreciated. Chip
Wayne
04-25-2000 10:33:51
 Re: need parts for super dexta in reply to Chip , 04-22-2000 23:42:24
The Dexta steering box is designed for wear compensation.If you will consult an I/T shop manual it will describe the procedure for removing the left side housing cover and removing washers from a shim pack to remove the free play. This often helps the hard steering some.Cheaper than a rebuild if it satisfies you.
Brian
04-27-2000 08:27:06
 Re: Re: need parts for super dexta in reply to Wayne, 04-25-2000 10:33:51
Chip,
Also check that the notches on either the front or rear of the stub axles at the top, line up with the ones on the steering arms. Adjust the track rods to get them correct equal each side.
post tractor numbers too please as these will help identify model.
regards
Brian
Oscar
04-23-2000 00:04:55
Where are you located?
Check out my site, it might be of help.
