Hi, Thanks. OK, I won't try and make them, unless I get desperate, in which case I shall make sure I do a really strong job. The flexible balls aren't too much of a problem because they are available as spare parts (the ball, socket, and a short stub to weld) from the local farm shop. While we are on the subject, someone gave me an old top link yesterday, but it's category 3. That's too big, isn't it? I do need to find a breakers' yard anyway, I need the part where the top link fixes to the tractor as well as the bits you know about already. At the moment the seat for the backhoe bolts on here, as well as to the casting down by the pto shaft. At present this (seat and support)is held on by a selection of studs, nuts and bolts. Any idea what the original bolt sizes were? Was there anything that bolted to the back of the tractor in the region of the pto? I can't see what could have been bolted here originally. When I unbolt the seat from here, will the axle oil come out, or are these blind holes in the casting? Yes, Brian, I have heard of Juko, I believe they are a subsidiary of Kongskilde(?), and they are on the other side of Finland (I'm in the South East, Southern Carelia). Cheers for now J-P PS. Couldn't borrow that horse harrow, the farmer thought I was a bit daft. He did very kindly offer me the use of his tractor rotary tiller and spring tyne harrow though, but I think that I don't have possibilities to fix the hitch in good time this year.
