MAJOR DIESEL PROBLEMS
JIM
06-05-2000 15:28:22
I have recently purchased a FORDSON MAJOR DIESEL in working condition, not restored.
It starts and runs fine . After using it to mow
for about 12 hrs. it began to overheat, and started popping out the exhaust. Now it does this all the time, and gets warm very quickly. It still seems to have plenty of power, and is not hard to start at all. It also seems to be idleing faster than it was. The popping happens when there is no load on the engine, or when I throtle down. If anyone has had a similar problem, and could help me with this, I would like to hear from you. thank you JIM
Brian
06-05-2000 15:57:21
 Re: MAJOR DIESEL PROBLEMS in reply to JIM, 06-05-2000 15:28:22
Jim,
Sounds like you may have a sticking exhaust valve,broken exhaust valve spring, or even worn rockers. Look in this area first by removing the valve cover.
regards
Brian
JIM
06-14-2000 15:11:30
 Re: Re: MAJOR DIESEL PROBLEMS in reply to Brian, 06-05-2000 15:57:21
BRIAN, THANKS FOR YOUR HELP. UPON LOOKING FURTHER INTO IT I FOUND A BROKEN VALVE SPRING. NOW, WHERE DO I GET THE PARTS, AND THE GASKETS TO GET THIS THING BACK TOGETHER? PLEASE LET ME KNOW.
THANKS JIM
