FMD starter noise
Baylor
06-12-2000 08:29:15
At times when I depress the starter handle on my '54 Major Diesel, the starter just whines. It might do this several times (usually when the tractor has run for a while)then it will crank the engine.
I have replaced the solenoid what could be causing this to happen?
muscats
06-13-2000 03:54:38
 Re: FMD starter noise in reply to Baylor, 06-12-2000 08:29:15
My FMD 55 does the same thing, I usually put it down to not pressing the starter lever forcefully enough. Though I think its a matter of the gears not engaging fully.
Brian
06-14-2000 13:54:12
 Re: Re: FMD starter noise in reply to muscats, 06-13-2000 03:54:38
Sounds like its clutch slip in the starter clutch. Could have got oil in from either oil leak from rear main oil seal or gear box. If its really bad, remove starter and dismantle, wash out clutch pack with petrol and reassemble.
If it is a grinding noise it could be starter ring gear needs replacement. This is a spliting job.
regards Brian.
