Light switch?
Hal
06-26-2000 22:05:20
Can somone tell me if this lever to the left of the tach on my Super Dexta is the light switch or what? Why does it have 5 positions? Most of the wiring ahead of the firewall is a mangled mess and I'm putting it back together without much to go by. Also, where are the glowplugs I keep hearing about? I'm pretty green on deisels and I can't find anything that looks like one to me. Thanks
Brian
06-29-2000 11:32:28
 Re: Light switch? in reply to Hal, 06-26-2000 22:05:20
Glow plug is in the inlet manifold. Trace the copper pipe to the manifold and "There she glows"
(Sorry)
Brian
degerb
06-29-2000 11:05:29
Yes, the switch you mentioned is indeed the lighting switch. Straight down is off; First right is Side and rear lamps; First left is Side, rear and dipped headlights; Second left is side, rear and main headlights; Third left is Main beam headlights only. I suggest you purchase the owners manual FO-O-Dexta from this site, lots of info but sorry to say no wiring diagrams that I'm aware of... perhaps Oscar or someone else might be able to help with that, Good Luck with your Dexta, Great little tractor!
