Super Major Leaking from axle
Joon E T
06-27-2000 07:12:04
Friend has a super M that is leaking oil out of the rear axle by the wheel hubs. Started when using the rear lift and appears to be from around the wheel drive shafts. Have been told its a major (no pun intended )job and not an uncommon problem. It has been suggested that we wind twine around the exposed area and use hose clips to pack this in tight and pack pump plenty of gerease in the axle grease nipples. Any info or ideas please
Jon
LEO WIGNELL
06-29-2000 23:59:32
 Re: Super Major Leaking from axle in reply to Joon E T, 06-27-2000 07:12:04
There is no quick fix for this job. Only satisfactory way is to remove axle and replace tin cover and seals, including cork and felt.
I have been a Ford/New Holland dealer for over 30 years-so have done many many axle seals.
Good Luck, LEO WIGNELL
roy
06-30-2000 03:15:07
 Re: Re: Super Major Leaking from axle in reply to LEO WIGNELL, 06-29-2000 23:59:32
do you recommend replacing the axle bearing at this time also???mine are leaking also.
LEO WIGNELL
06-30-2000 05:03:12
 Re: Re: Re: Super Major Leaking from axle in reply to roy, 06-30-2000 03:15:07
Bearing should be okay. Check carefully for pitting especially if any moisture has been in the back end. Because of the size of back end, they are prone to condensation, even if shedded.
Regards, Leo wignell
