Fordson Help!!!
Patrick
07-03-2000 22:01:43
third party image
I need to know the value and a good buying price for a Fordson F in this condition.
It does not run, the motor is not stuck, it has a mag., it has the carb and intake, but the intake tube has a hole rusted in it. The cluch pedal will go up and down, and the shifter feels like it goes into the gears with no problem. Thanks for any help.
RLL
07-22-2000 07:46:52
 Re: Fordson Help!!! in reply to Patrick, 07-03-2000 22:01:43
I hope the photo you scanned in is not the tractor you have in mind. Looks like a 51/52 8N
When you say the intake tube has a hole in it, do you mean the vapor tube or air washer tube. If you
are refering to the vapor tube, and the carb and air mixer are intact mounted on the 648B intake, you've got a prize if in decent condition. There alone is several hundred if you purchase them individually. Why don't you photograph the unit and scan IT in as the above 8N for a better appaisal Re year, condition, etc. RLL
