Att: Brian, Ref. 62 Super Dexta
Tetx
07-12-2000 17:36:45
Brian: Just wanted to let you know I finally found the problem with the Hydraulic lift on my tractor. If you recall, the only time the lift would work was after I removed and inspected the unload valve. It worked a couple of times then quit again. I found a diagram of the hydraulic system and decided the unload valve had to be the problem, although it looked good with no contamination. I took it out again and replaced the "O" ring and the lift worked as advertised. The only thing I can figure out was the "O" ring swelled up, causing the valve to stick. Thanks again for leading me to the problem. Tetx
Brian
07-15-2000 06:38:07
 Re: Att: Brian, Ref. 62 Super Dexta in reply to Tetx, 07-12-2000 17:36:45
Tetx,
Thanks for letting me know. We used to remove the "O" ring and throw it away. Ford replaced it with a cast ring on the later tractors.
regards
Brian
