Super major 5000 engine blow by water in oil
Joe in KY.
07-12-2000 17:48:52
1963 english super major 5000 diesel runs strong and cool but experiencing water in oil. Tractor sat idle for five years outside but starts and runs well. Have drained oil twice and refilled but oil is still milky.Also oil is blowing out of crankcase ventilator and breather oil cup. all possible suggestions will be appreciated.
brent
02-03-2001 08:34:53
 Re: super major 5000 engine blow by water in oil in reply to Joe in KY., 07-12-2000 17:48:52
hey Joe sounds like the same problem I had with my 61 major. one of the cylinder sleaves has got bad "o" rings in it or it has droped down in the block and your getting preasure and water in the oil. I had to put new "o" rings in and shim one of the sleaves up so that the sleave sticks up above the block by .005" . And this fixed it once and for all. its a lot of work but so is all the head gaskets i put on before finally fixing it right.
Steven B
07-12-2000 20:07:38
Joe
The most probable cause is the O rings at the bottom of the sleeves that are leaking. This could be compounded by electrolisis that eats away the sleeve and block. If your tractor has been stood a long time however I would take a punt that the O rings have just perished and are now leaking. Also the piston rings sound like thier used by date has passed.
The O rings are not expensive, but you will need a head gasket set and a new sump gasket. This is what you will need to do:
1 Remove head
2 Remove Sump
3 Remove the Piston/rods.
4 Remove Sleeves.
5 Clean O rong grooves at bottom and top of the block (your engine will be the later type with 2 O rings per cylinder).
6 Replace O rings.
7 Re install sleeves.
8 Re assemble the rest of the engine.
To remove the sleeves you will need a sleeve puller. Make one from two foot of 3/4in threaded rod with two nuts. You will need a pice of 2in wide by 6in long by 1/2in thick plate with a hole in the centre to go on the top of the block. The rod drops through the hole and I place two blocks of wood either side of the sleeve to make a bridge with the plate spanning. For the bottom, get yor local machine shop to make you a large "washer" 104 mm diameter with a 98mm diameter step. The hole is for the threaded rod. Make sure the crank is at bottom dead centre and I usualy wrap a clean rag around the journal because a lot of crud will fall out when the sleeve is removed. Also, dont hit the crank with the pulling rod. The step in the washer faces up into the cylinder. The sleeves take a bit of moving so make sure everything is square before you start to pull one out.
Depending on you budget and how good the tractor is I would at a minimum install new rings and big end bearings. They are not that expensive. Check the sleeves where the O ring sits, if its badly coroded you may be better geting a engine kit. There are two kinds, one that does the whole engine and one that just has pistons, sleeves, big ends and gaskets. By the time you buy gaskets, rings and bigends, the basic kit may not be that much more.
Hope this hasn't spoiled your day out. I am just about to rebuild the engine in my Super Major.
Steven B
Steven B
07-13-2000 02:51:58
 Re: Re: super major 5000 engine blow by water in oil in reply to Steven B, 07-12-2000 20:07:38
Steven,
Thanks Very much for your quick response. I Suspected the head gasket and was hoping for the best but have budgeted for the rebuild.This will really be the 5000 when I'm done,as in $5000 for the complete restoration.Oh,well at least I will know that I've got a very solid tractor. They certainly don't build them this good anymore.Do you have any suggestions as to the best place to locate the rebuild kit? Thanks again!
