Fordson loader pressure
peter w
07-17-2000 01:56:02
I have a fordson super major Moore front loader, with a crankshaft mounted DOWTY pump. With just the bucket, movement of all rams is excellent. However, lifting moderate loads causes creaks from the pump and a juddering through the system, and the load raises slowly. I was expecting to be able to almost lift the back of the loader off the ground. I am not sure if it is the pump or the relief valve setting. Do you know what pressure the relief valve should run at? If it is low, I can shim the valve: if no change it would be the pump, if improves, it would be the valve. Any comments?
Thanks,
Peter w.
