Steering power assist for dexta 1959
Col Walker
07-20-2000 02:09:28
My Dexta has been working in my vineyard at Orange in New south Wales Australia for many years. I have just introduced front set of forks to move pallets. works ok little heavy on the steering.I have an auillary oil pump and tank driven from the front flywheel. any ideas for power assit to this workhorse of mine someone must have done this somewhere any ideas. ColW
Burrhead
07-21-2000 17:35:15
 Re: steering power assist for dexta 1959 in reply to Col Walker , 07-20-2000 02:09:28
Col I never put one on but I have seen one.
A neighbor took the power assist cylinder from a 60's or 70's IHC 2 ton fire truck.
He took the steering rods off that run from the steering box to the wheels.
He built a tie rod for under the frontend from left to right side.
He cut the left steering rod in two and put the power assist into the left steering rod and put it back on.
At first I did'nt see how it would work at all, but it works beautifully. He did'nt use an auxillary pump he plumbed his into the pressure check plug in the hydraulic pump cover plate.
Col Walker
07-25-2000 01:42:56
 Re: Re: steering power assist for dexta 1959 in reply to Burrhead, 07-21-2000 17:35:15
Thanks for your input Burrhead .I have been looking at an old massey header with rear power assist . This cylinder could well do the job any thoughts about the removal of the steering box from the Dexta and replacement with controller driven by the steering wheel.Thanks again.
ColW
Burrhead
07-27-2000 15:10:49
 Re: Re: Re: steering power assist for dexta 1959 in reply to Col Walker, 07-25-2000 01:42:56
Sorry I could'nt get back to you sooner Col.
I've never seen a Dexta done like you're talking about but they're is'nt any reason why it would'nt work if you can find the set up.
The reason I like how this fellow did his is that it would look like a factory job if he would just fix his pressure supply into somewhere else instead of out the pump plate plug.
