Dynamo
jan de Monchy
07-29-2000 14:31:07
Hello,
Today I tried the dexta that I bought this week.The first problem occured:the accumulator was almost empty.I think the dynamo is not charging,but the red indicator light does stop buning when the motor starts running.Are there any trics with the voltmeter to find out?what should the readings be approx.? Jan.
Pete Tatham
07-30-2000 01:32:10
 Re: dynamo in reply to jan de Monchy, 07-29-2000 14:31:07
Jan, Heres how I test a dynamo;- 1. Take out the plug-in connectors and join the sockets with a short length of wire. 2. Connect a voltmeter, (0-20 volts) between the two sockets and dynamo housing. 3. increase the engine speed slowly and note the voltmeter reading. This should be 12 volts at low revs. Dont run engine above around 1200rpm. If no reading given, or if its low or erratic, dynamo is faulty and needs a strip down. Unless very badly worn you can usually get away with undercutting the mica segments on the commutator and replacing the brushes. Good luck, Pete.
Pete Tatham
07-30-2000 01:30:40
