FORDSON MAJOR DIESEL 1955 IN AUSTRALIA
john
08-05-2000 22:46:18
i have a 1955 FMD and i have a problem with the rear axle/hyraulics oil.
the oil is a creamy colour and i would like to stop the problem for GOOD
the temp is about 20 - 25 degrees celcius
we also have a front end loader attached
please any info regarding the above will be gratefully accepted
Don(CO)
08-06-2000 08:34:41
 Re: FORDSON MAJOR DIESEL 1955 IN AUSTRALIA in reply to john, 08-05-2000 22:46:18
John:
The creamy hydraulic fluid is indicative of water contamination... the New Performance majors were notorius for leaking water in the differential from two places.. A.The dipstick opening on the front left differential housing by your left foot. B. the vented fill cap at the top rear of the differential cover.
I place a plastic hydraulic hose cap over the vent cap of mine if it has to set outside in the rain. A little rubber washer between the dipstick and the cast housing might prevent some liquid from entering that opening. Best bet is to keep it inside. You will still accumulate some moisture in the differential from condensation.
Oscar
08-06-2000 23:11:17
 Re: Re: FORDSON MAJOR DIESEL 1955 IN AUSTRALIA in reply to Don(CO), 08-06-2000 08:34:41
Yep, water is the culprit here. And yes, Majors are notorious for that. I'd advise replacing the oil in the rear axle, because this is the same oil that the hydraulic system uses. There's a lot of oil in there, and replacing it might you cost you some, but I advise it nonetheless.
Brian
08-07-2000 07:57:14
 Re: Re: Re: FORDSON MAJOR DIESEL 1955 IN AUSTRALIA in reply to Oscar, 08-06-2000 23:11:17
Chaps,
Is'nt life strange. We live in England where it is fairly wet. My Major has to live outside all year without a shed or cover. The rear axle oil is as old as the tractor (1952) and has never shown any indication of water. There is no evidence of condensation either. I wouls suspect that it is humidity that is the problem rather than rain.
regards
Brian
L. wignell
08-16-2000 06:37:56
 Re: Re: Re: Re: FORDSON MAJOR DIESEL 1955 IN AUSTRALIA in reply to Brian, 08-07-2000 07:57:14
Yes, condensation is the culprit. As the housing is cast, this helps cause the problem. Even if shedded. Change oil more often, oil is cheaper than reconditioning back ends.
