Super Major has knock with clutch out
Bruce
08-19-2000 18:48:17
As soon as I depress the clutch, the knock ceases. Does anyone have an idea what may be loose? Thanks, Br
Bruce
08-20-2000 10:19:25
 Re: Super Major has knock with clutch out in reply to Bruce, 08-19-2000 18:48:17
Brian, thanks for the help! I guess Ill have to split the tractor right away. I just bought it! Oh well, better to fix it now. Thanks again! Br
Bruce
08-20-2000 08:29:53
As long as the tractor is running, it knocks like a bad rod bearing. When clutch is depressed, it goes away completely. Pto in or out makes makes no difference. Thanks!
Brian
08-20-2000 09:07:29
 Re: Re: Super Major has knock with clutch out in reply to Bruce, 08-20-2000 08:29:53
Bill,
If it is in the area of the clutch housing it could be a loose flywheel. I would suggest that you run the engine as little as possible until you have found the problem.
Does the tractor still drive?
Did it come on suddenly?
What were you doing at the time?
regards
Brian
Don(CO)
08-20-2000 05:55:48
Bruce:
Does the knock occur in all forward gears, including High and Low range? Or does it occur only in a certain gear and range? Is it more difficult to put into gear without grinding the gears now than before this knock began?
Give us a 'bit' more to go on... and we'll "knock" this subject around a little. :-)
Brian
08-20-2000 02:25:35
Bill,
Could be anything behind clutch, eg. Gearbox, final drives, pto etc. Can you give more info. Also what sort of knock? Is it heavy, light, rattly etc.
regards
Brian
Brian
08-20-2000 09:09:59
 Re: Re: Super Major has knock with clutch out in reply to Brian, 08-20-2000 02:25:35
Bruce,
Sorry brain not in gear when I called you Bill. Sorry.
Brian
