RPM sensor / hyd oil grade ?
Jack.C
08-22-2000 07:56:16
did someone know where the RPM sensor is on my dexta 1960 I have no reading and I suspect that
the last owner unplug it for removing some hour.
Also is it W90 grade for dexta to for the hyd oil
I have a front loader if this change someting.
Burrhead
08-22-2000 10:45:22
 Re: RPM sensor / hyd oil grade ? in reply to Jack.C, 08-22-2000 07:56:16
Jack there is'nt a sensor on a Dexta.
The proof meter was a mechanical cable type, like a speedometer cable.
The very rear end of the injector pump has a male end cable adapter sticking out, the cable attaches there and goes to the center of the dash gauge site, (to the big hole in the dash board). Or meter if it's still there.
TSC or CT have the reproduction meters, or about any NAPA store has the RPM gage and can build you a new cable.
Where I live here the new gage and new cable cost about $30 total price for both.
P.S. Burrhead
08-22-2000 10:49:41
 Re: Re: RPM sensor / hyd oil grade ? in reply to Burrhead, 08-22-2000 10:45:22
I forgot the hyd oil. Yes 90W is fine.
If you use the loader in cold weather you might want to use 30W or 50W oil to speed it up.
The differential capacity is 5 gals plus 1 pint for the tractor plus whatever for the loader and lines.
What kind of loader do you have on it??
Jack.C
08-23-2000 04:16:44
 Re: Re: Re: RPM sensor / hyd oil grade ? in reply to P.S. Burrhead, 08-22-2000 10:49:41
Burr
my loader is an ARPS model 1200 not shure if arp take an s at the end or not there is paint over the plate. btw my proof meter as no cable that is why it doesn't work so now I will have to call NAPA to see if they have one.
regards
Jack.C
Burrhead
08-23-2000 11:06:56
 Re: Re: Re: Re: RPM sensor / hyd oil grade ? in reply to Jack.C, 08-23-2000 04:16:44
Thanks Jack,
I'll see what I can find on a loader here.
Yessir the cable will keep it from working anytime. Good luck and thanks again. Jerry
Jack.C
08-22-2000 12:14:32
Thanks for all these info Burrhead
I will check for the brand of my loader and I will let you know tomorrow.I realy appreciate your help
Regards
Jack.C
